Knowledge Base Article
What are the recommended SATA/SAS Signal Detect Preliminary Settings for Arria V GT/GX/ST/SX and Cyclone V GX/SX devices?
Description
Currently, SATA/SAS characterization for Arria® V GT/GX/ST/SX and Cyclone® V GX/SX devices are preliminary. Prior to availability of final characterization data, follow the recommended Signal Detect settings below:
Quartus II QSF
Assignment Settings
Signal Detect Detection Time
RX Vcm
Signal Detection Threshold Voltage
XCVR_RX_SD_ON
XCVR_RX_SD_OFF
XCVR_RX_COMMON_
MODE_VOLTAGE
XCVR_RX_SD_THRESHOLD
i/m Variant
X Variant
Arria V GT/GX/ST/SX
Gen 1
2
2
0.65 V
5 (40 mV)
7 (50 mV)
Gen 2
4
2
Gen 3
8
4
Cyclone V GX/SX
Gen 1
5
4
0.65 V
5 (40 mV)
7 (50 mV)
Gen 2
3
2
Notes:
  • These settings are allowed in Quartus® II software 13.0 DP1 and later versions.
  • You can change the QSF setting with different XCVR_RX_SD_ON and XCVR_RX_SD_OFF values based on your system level testing.
Example of signal detect QSF assignment for the Arria V device Gen 3 (6Gbps) and m variant:
1) Enable signal detect circuit
set_instance_assignment -name XCVR_RX_SD_ENABLE ON -to <rx_serial_pin name>
2) Setting hysteresis of the detection time
set_instance_assignment -name XCVR_RX_SD_ON 8 -to <rx_serial_pin name> (1)
set_instance_assignment -name XCVR_RX_SD_OFF 4 -to <rx_serial_pin name> (1)
3) Setting the RX common mode voltage
set_instance_assignment -name XCVR_RX_COMMON_MODE_VOLTAGE VTT_0P65V -to <rx_serial_pin name>
4) Setting the detection of threshold voltage
set_instance_assignment -name XCVR_RX_SD_THRESHOLD 5 -to <rx_serial_pin name> (1)
Note:
  1. Refer to Altera Transceiver IP Core User Guide (PDF) for corresponding XCVR_RX_SD_THRESHOLD values and supported XCVR_RX_SD_ON and XCVR_RX_SD_OFF values.
Resolution
Updated 11 months ago
Version 3.0
