Knowledge Base Article
What are the programmable IOE delay specifications for Intel® MAX® 10 devices with -I6 speed grade?
Description
The Intel® MAX® 10 FPGA Device Datasheet currently doesn’t provide the programmable IOE delay specifications for -I6 speed grade.
You can find the programmable IOE delay specifications for Intel® MAX® 10 devices with -I6 speed grade in the following table.
< Programmable IOE Delay for Intel® MAX® 10 Device -I6 speed grade (Slow Corner) >
Parameter
Row
Column
Slow corner (ns)
Input delay from pin to internal cells
1.797
1.788
Input delay from pin to input register
2.042
2.02
Delay from output register to output pin
1.049
0.952
The specifications for fast corner are the same as -I7 speed grade. Refer to Programmable IOE Delay for Row Pins and Programmable IOE Delay for Column Pins in the Intel® MAX® 10 FPGA Device Datasheet.
Resolution
The programmable IOE delay specifications for -I6 speed grade Intel MAX 10 devices will be added in a future release of the Intel® MAX® 10 FPGA Device Datasheet.
Updated 6 days ago
Version 3.0
