Knowledge Base Article
Warning(12620): Input port OE of I/O output buffer "~ALTERA_MSEL<n>,<SDM_IO function>~~obuf" is not connected, but the atom is driving a bi-directional pin
Description
You may see a warning message like the one above when compiling your Intel® Stratix® 10 design in the Intel Quartus® Prime Pro Edition Software version 17.0 and later.
The warning message may refer to one of the MSEL (0..2) pins and an SDM_IO function that is being used on that pin (e.g., CONF_DONE, INIT_DONE, HPS_COLD_RESET, HPS_WARM_RESET, etc.)
There is no requirement to make any internal connection to this pin, and this warning message can be safely ignored.
Resolution
This warning message can be safely ignored.
Updated 11 months ago
Version 3.0
