Knowledge Base Article
WARNING: Tcl script <file name> error: Module "none" doesn't exist in SOPC design "nios_setup".
Description
Due to a problem in the Quartus® II software, if you uncheck Enable for any driver in the Drivers tab of BSP Editor for Nios® II, export a tcl file, and specify it as an option of some command like nios2-bsp, you will get the tcl script error.Resolution
To work around this problem, open the tcl file in a text editor and swap the 2 operand of set_driver command. For example, if you disable led_io driver, you will get a line below.
set_driver led_io none
Then modify the line like below.
set_driver none led_io
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
