Knowledge Base Article
Warning Messages for Stratix V Designs
Description
When you compile a design that targets a Stratix V device, the Quartus II software displays the following warning messages for various values of <suffix>:
Warning: Ignored filter: *alt_xcvr_csr_<suffix> could not be matched with a register Warning: Ignored set_false_path: Argument <to> is an empty collection Warning: Ignored filter: *altera_tse_reset_synchronizer_chain*|aclr could not be matched with a pin
You may safely ignore the warning messages.This issue affects all Stratix V designs.
Resolution
No workaround.This issue will be fixed in a future version of the Triple-Speed Ethernet MegaCore function.
Updated 11 months ago
Version 3.0
