Knowledge Base Article
Warning Messages Displayed for UniPHY External Memory Interfaces When Compiling for Stratix V Devices
Description
When compiling a design for Stratix V devices, the system may display numerous PLL-related warning messages similar to the following:
Warning: PLL(s) placed in location FRACTIONALPLL_X0_Y1_N0
do not have a PLL clock to compensate specified - the Fitter will
attempt to compensate all PLL
use multiple different clock network types - the PLL will compensate
for output clocks
Warning: PLL cross checking found inconsistent PLL clock
settings:
Warning: Node: mem_if|controller_phy_inst|memphy_top_inst|pll1~FRACTIONAL_PLL|mcntout was
found missing 1 generated clock that corresponds to a base clock with
a period of: 8.000
Warning: Clock: mem_if|ddr3_pll_write_clk was found on
node: mem_if|controller_phy_inst|memphy_top_inst|pll3|outclk with
settings that do not match the following PLL specifications:
Warning: -multiply_by (expected: 21, found: 4264000)
Warning: -divide_by (expected: 5, found: 1000000)
Warning: -phase (expected: 0.00, found: 90.00)
These warning messages are expected and can be ignored.
Resolution
There is no workaround for this issue. You can safely ignore the error messages.
Updated 20 days ago
Version 3.0No CommentsBe the first to comment
