Knowledge Base Article
Warning: Ignored location assignment to pin_perst_n_1_2 (with value PIN_*) as it does not specify a building block.
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.2 and earlier, you may see the warning below in compilation if adding pin location assignment or back annotate pin location to the Agilex™ 7 FPGA F-Tile reset port :
It's safe to ignore this warning.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 23.3
Updated 11 months ago
Version 3.0
