Knowledge Base Article
Warning: ex_25g.alt_e25s10_0: The current selected device "1SG280HU2F50E2VGS1" is an engineering sample device, which might not be able to meet timing requirement for this IP. Please consider to migrate to production device that is equivalent.
Description
You may encounter the above warning in the IP Parameter Editor System Messages pane when trying to generate a 25G Ethernet Stratix® 10 FPGA IP instance for a Stratix® 10 device with H-Tile ES1 or ES2 silicon.
Resolution
To work around this warning, you must target a Stratix® 10 device with H-Tile ES3 or Production silicon when creating your project in Quartus® Prime Pro Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
