Knowledge Base Article
Warning (332174): Ignored filter at *_altera_stratix10_interface_generator_*.sdc(3): emac_ptp_ref_clock_clk could not be matched with a port.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v21.3 or earlier, you may see the following warning message when enabling the emac_ptp_ref_clock_clk pin in the HPS of the Intel® Stratix® 10 device:
Warning(332174): Ignored filter at *_altera_stratix10_interface_generator_*.sdc(3): emac_ptp_ref_clock_clk could not be matched with a port.
Resolution
To work around this problem, please use the timing constraint like the following description:
create_clock -period <period value> -name <clock_name> [get_ports {target emac_ptp_ref_clock_clk name}]
This problem is fixed starting with the Intel® Quartus® Prime Pro/Standard Edition software version 22.4.
Updated 2 months ago
Version 3.0
