Knowledge Base Article
warning (19049) the derive_pll_clocks command is not supported in this family
Description
This warning may be seen in the Quartus® software 17.0 and later when your Stratix 10 project contains derive_pll_clocks SDC constraint.
Resolution
To avoid this warning, you can delete this constraint from SDC file. The project using Stratix 10 device can automatically derive pll clocks.
Updated 11 months ago
Version 3.0
