Knowledge Base Article
V2. Internal Error: Sub-system: HDB, File: /quartus/db/hdb/hdb_entity_wildcard_expander.cpp, Line: 846
Description
ue to a problem in the Quartus® Prime Pro Edition Software version 25.1.1, you might see this error when using assignments in your Quartus® Settings File (.qsf) to describe NoC connections on Agilex® 7 FPGA M-series devices. Specifically, you may see this error if your assignment targets a relative path name (without wildcards) with an -entity argument.
For example:
set_instance_assignment -name NOC_CONNECTION ON -from soc_inst|agilex_hps|intel_agilex_hps_inst|iniu_0|initiator_inst_0 -to soc_inst|hbm|hbm_fp_0|hbm_fp_0|tniu_ch2_u0|target_0.target_inst_0 -entity design_top
Resolution
To work around this problem, edit the assignment to remove the -entity argument and use it as part of the full path name. For example:
set_instance_assignment -name NOC_CONNECTION ON -from design_top|soc_inst|agilex_hps|intel_agilex_hps_inst|iniu_0|initiator_inst_0 -to design_top|soc_inst|hbm|hbm_fp_0|hbm_fp_0|tniu_ch2_u0|target_0.target_inst_0
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 5 months ago
Version 4.0
