Knowledge Base Article
Unable to Install DS-5: Error running msiexec
Description
You might see an error message similar to the following when you try to install DS-5:
Error running msiexec ... Program ended with an error
exit code
The DS-5 installer does not run correctly if the 8dot3name extension is not enabled on the volume where you attempt to install.
Resolution
Avoid installing DS-5 to a path name containing spaces.
If it is necessary to support spaces in the path name, enable the 8dot3name extension on the installation volume. For further information, refer to:
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
