Knowledge Base Article
U-Boot Times Out During FPGA Programming
Description
On the Cyclone V SoC HPS, U-Boot might time out without completing,
and report an error code of -6, indicating that the FPGA control
block cannot obtain valid data. This can happen if the FPGA manager
exits the initialization phase before U-Boot tests for it. As a
result, the value of the FPGA manager’s stat.mode field
is USERMODE, and U-Boot times out waiting for stat.mode to
be set to INITPHASE.
Resolution
Edit the U-Boot source file arch/arm/cpu/armv7/socfpga/fpga_manager.c.
Modify the stat.mode test to allow either stat.mode = INITPHASE or stat.mode = USERMODE.
Alternatively, upgrade to v13.1 or later.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
