Knowledge Base Article
Triple Speed Ethernet IP Core Cyclone IV VHDL Customer Testbench Fail to Run
Description
The Triple Speed Ethernet (TSE) IP core VHDL customer testbench targeting Cyclone IV devices for the following settings may fail to run:
Core variation: 10/100/1000Mb Ethernet MAC with 1000BASE-X/SGMII PCS
Use internal FIFO: No
Number of ports: 4
Transceiver type: GXB
Export transceiver powerdown signal: Yes
Resolution
Perform these steps to modify the testbench file:
1. Open the top-level testbench file, <instance_name>_tb.vhd.
2. Search for generate-block with the name "FourPort_DUT_without_FIFO".
3. Add the following lines in the generate-block:
gxb_pwrdn_in_0 <= gxb_pwrdn_in; gxb_pwrdn_in_1 <= gxb_pwrdn_in; gxb_pwrdn_in_2 <= gxb_pwrdn_in; gxb_pwrdn_in_3 <= gxb_pwrdn_in;
This issue will be fixed in a future release.
Updated 11 months ago
Version 3.0
