Knowledge Base Article
TCP DSTREAM Connection Fails with Trace Enabled
Description
If you try to start a DS-5 debug configuration that connects to the target using DSTREAM over Ethernet, and the 4 GB DSTREAM trace buffer is enabled, the connection fails. You see a message similar to the following:
Failed to open connection to DSTREAM trace server at <hostname>
Resolution
Add "TCP:" as a prefix to the host name of the target DSTREAM device. For example, if the host name is device1.example.com, specify the connection target as TCP:device1.example.com.
Updated 11 months ago
Version 3.0
