Knowledge Base Article
Should CONF_DONE and INIT_DONE assert high during Stratix® 10 FPGA JIC file programming with the Quartus® Prime Pro Edition Software v18.0?
Description
No, the CONF_DONE and INIT_DONE signals should not assert high during Stratix® 10 FPGA JIC file programming.
When using the Quartus® Prime Pro Edition Software v18.0 to configure an Stratix® 10 FPGA device with the helper image (Factory default SFL image) during the JIC file programming process, you might observe unexpected CONF_DONE and INIT_DONE signal assertions. The helper image (Factory default SFL image) only contains firmware data and not the full configuration data. Thus, the Stratix® 10 FPGA device is only configured with the firmware data, and even though the CONF_DONE and INIT_DONE signals are asserted high, the Stratix® 10 FPGA device has not entered the user mode.
In the Quartus® Prime Pro Edition Software v17.1 and earlier, the CONF_DONE and INIT_DONE signals are expected to be asserted high as the helper image (Factory default SFL image) contains full configuration data.
Resolution
This invalid CONF_DONE and INIT_DONE state will not cause any JIC programming failure.
This is fixed in the Quartus® Prime Pro Edition Software v21.4 and above.
Updated 2 months ago
Version 2.0
