Knowledge Base Article
rx_use_coreclk parameter is not generated correctly for 10GBASE-R PHY v12.0 megafunctions that target the Stratix V device family
Description
10GBASE-R PHY v12.0 megafunctions that target Stratix V devices do not generate rx_use_coreclk parameters correctly; the generated HDL file does not pass the rx_use_coreclk parameter to the sv_xcvr_10gbaser_nr instance.
Resolution
Update the generated HDL file to pass the parameter. For a file generated in System Verilog, add the line commented in the example below:
sv_xcvr_10gbaser_nr #( .num_channels (num_channels ), .operation_mode (operation_mode ), .sys_clk_in_mhz (mgmt_clk_in_mhz ), .ref_clk_freq (ref_clk_freq ), .rx_use_coreclk (rx_use_coreclk ), //add this line .pll_type (pll_type ), .RX_LATADJ (rx_latadj), .TX_LATADJ (tx_latadj) )xv_xcvr_10gbaser_nr_inst(
Updated 11 months ago
Version 3.0
