Knowledge Base Article
Root Port Bus Functional Model (BFM) and Endpoint Design Example Not Available
Description
The root port BFM and endpoint design example are not available for simulation in version 11.0 SP1 of the Quartus II software. If you begin simulation, the following message displays, “BFM model not available.”
This issue affects the root port and endpoint design examples described in the “Testbench and Design Example” chapter of the Stratix V Hard IP for PCI Express User Guide.
Resolution
This issue is fixed in special version 12.01 of the Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
