Knowledge Base Article
quartus_pgmw: error while loading shared libraries: libicui18n.so.61: cannot open shared object file: No such file or directory
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v19.1, you may see this error when using the Intel® Quartus® Prime Pro Edition Software Programmer in Linux operating system (OS).
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software Programmer v19.1, download and install patch 0.01p from the following links:
Note: You must install the Standalone Intel® Quartus® Prime Software Programmer v19.1 before installing this patch.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software v19.2.
Updated 8 months ago
Version 3.0
