Knowledge Base Article
Possible Timing Failures for LPDDR2 Designs on Cyclone V -7 Speed Grade Devices
Description
This problem affects LPDDR2 products.
LPDDR2 designs targeting Cyclone V -7 speed grade devices at 333 MHz may fail address and command timing analysis.
Resolution
The workaround for this issue is to operate the design at a lower frequency (such as 300 MHz), or use a -6 speed grade Cyclone V device.
This issue will be fixed in a future release.
Updated 3 months ago
