Knowledge Base Article
No 28nm Device Support for 10G Soft-XAUI Design Example
Description
The 10G soft-XAUI design for the Stratix V PCI Express (PCIe) development kit is unable to complete the fitter process when the pin assignments at the high-speed mezzanine card (HSMC) Port A are using the transceiver channels 0, 2, 3, and 4.
The 10G XAUI hardware design cannot be tested for the Stratix V SI development kit because the design is unable to interface with the external tester.
The 10G XAUI design is unable to meet the timing analysis for the Cyclone V PCIe development kit in the Quartus software.
This issue affects the 10G Ethernet 12.1 designs in the Cyclone V and Stratix V 28nm devices.
Resolution
There is no workaround for this issue.
This issue will be fixed in a future ACDS release.
Updated 11 months ago
Version 3.0
