Knowledge Base Article
Mixer II IP Core Input Frames Do Not Appear When Enabled
Description
The Mixer II IP core does not display an input stream when you enable the input by setting bit 0 of the corresponding input enable register.
Resolution
To fix this problem, set bit 0 and bit 2 of the input enable register.
This issue will be fixed in a future version of the Mixer II IP core.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
