Knowledge Base Article
Low Latency 40-100GbE IP Core Targeting Stratix V Device With 322 MHz Reference Clock Has Wrong RX MAC Clock Frequency
Description
The LL 40-100GbE parameter editor provides two possible values for the PHY reference frequency parameter. Both values should generate a clk_rxmac frequency of 312.5 MHz for 40GbE variations and 390.625 MHz for 100GbE variations.
However, in IP core variations with the following properties, the clk_rxmac frequency is different:
  • The target device family is the Stratix V device family.
  • The PHY reference frequency parameter has the value of 322.265625 MHz.
Resolution
This issue has no workaround.
This issue will be fixed in a future version of the Low Latency 40- and 100-Gbps Ethernet MAC and PHY MegaCore function.
Updated 11 months ago
Version 3.0
