Knowledge Base Article
LL 40-100GbE IP Core: Pause Frames with Error(s) are accepted
Description
For both standard flow control and priority flow control modes, the pause frames with FCS error or size error will still trigger the IP to pause in TX.
Resolution
This issue has no workaround.
This issue will be fixed in a future version of the Low Latency 40- and 100-Gbps Ethernet MAC and PHY IP core.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
