Knowledge Base Article
Limitations in Support for 400MHz DDR3 Hard Memory Controller With MPFE Interfaces Targeting Cyclone V Devices
Description
This problem affects DDR3 products.
The following limitations exist in support for 400MHz DDR3 hard memory interfaces with multiport front end, targeting Cyclone V devices:
Issue 1:
Hardware test using the example design might fail even if there is no timing violation reported in TimeQuest.
Issue 2:
Avalon data widths greater than 64 bits are not supported.
Issue 3:
Correct operation of the unidirectional Avalon port has not been verified.
Resolution
The following workarounds apply to these issues:
Issue 1:
Setup and hold timing margin for transfers between hard memory controller and core logic might not be balanced. Use set_min_delay constraint to increase the hold time margin for transfers between the hard memory controller and the core logic.
This issue will be fixed in a future version.
Issue 2:
Use Avalon data widths of 32 bits or 64 bits.
Data widths of 128 and 256 bits will be supported in a future version.
Issue 3:
There is no workaround for this issue.
Operation of the unidirectional Avalon ports will be verified in a future version.
Updated 11 months ago
Version 3.0
