Knowledge Base Article
Jitter Tolerance of SDI Receiver Reduced for SD-SDI
Description
The jitter tolerance for SDI receiver (SDI and SDI II IP cores) degrades when it receives SD-SDI video. The tolerance value drops from 0.4 UI to approximately 0.2 UI.
This issue causes the SDI receiver to recover wrong data when it receives SD-SDI video with high jitter (more than 0.2 UI).
Resolution
There is no workaround for this issue.
This issue is fixed in version 15.1 of the SDI and SDI II IP cores.
Updated 11 months ago
Version 3.0
