Knowledge Base Article
Is there a reference on how to enable internal serial loopback mode for the GTS Transceiver PMA link for usage with data rate < 7Gbps?
Description
If you are referring to the Quartus® Prime Pro Edition software version 25.1.1, and plan to enable or disable internal serial loopback mode for your GTS Transceiver for:
- Example designs mentioned below or
- 1 x 1G PMA Direct Mode (System PLL Clocking) with Custom Cadence
- 1 x 3.125G PMA Direct Mode (System PLL Clocking) with Custom Cadence
- Any protocol implementation that is less than 7Gbps with RX manual adaptation mode
You can refer to enabling or disabling the internal serial loopback procedure (run_test_silb_bypass) from the main.tcl file.
However, this example procedure is currently not available in the main.tcl script.
This main.tcl script is generated as part of the example design generation flow and stored in the “hwtest” folder.
Resolution
You can refer to the attached hwtest.zip file as an example to enable or disable the internal serial loopback procedure of the GTS Transceiver.
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.3.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
