Knowledge Base Article
Is there a known problem with VREF pin reporting in the Intel® Quartus® Prime Pro Edition Software version 21.4 when using Intel® Stratix® 10 devices?
Description
Yes, due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.4, the "All Package Pins" report will show incorrect VREF requirements for Intel® Stratix® 10 devices when no GPIOs in the respective I/O bank use a voltage standard that requires a VREF.
Resolution
To work around this, compare the Pin Planner settings for the respective bank with the Intel Stratix 10 Device Datasheet I/O Standard Specifications VREF requirement.
If all your pins in the bank do not require a VREF, then connecting the VREF pin to GND is safe.
This problem will be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
