Knowledge Base Article
Is there a known problem with how the Intel® Quartus® Prime Pro Edition Software implements Differential SSTL and HSTL I/O in Intel® Stratix® 10 devices?
Description
Yes, due to a problem in the Intel® Quartus® Prime Pro Edition Software versions 17.0 or later, Differential SSTL and HSTL inputs might not sample the input signal when implemented on bi-directional I/O in Intel® Stratix® 10 devices if the respective VREF pin is not connected to a voltage reference. Differential SSTL and HSTL inputs should not require a VREF.
Resolution
This problem is fixed starting from the Intel® Quartus® Prime Pro Edition Software version 19.3.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
