Knowledge Base Article
Is there a known Parallel Flash Loader II FPGA IP issue when configuring Agilex™ 7 FPGA series devices in Avalon-ST configuration mode?
Description
Yes, due to a problem with the Parallel Flash Loader II FPGA IP (PFL-II) in Quartus® Prime Standard Edition Software version 23.1 and earlier, you may see configuration fail with some bitstreams when configuring Agilex™ 7 FPGA series devices in Avalon-ST configuration mode.
Resolution
Upgrade the Parallel Flash Loader II FPGA IP in Quartus® Prime Standard Edition Software version 23.1.1 or implement the workaround in Why does PFL-II IP not meet Agilex™ 7 'nCONFIG high to nSTATUS high' timing specifications for FPGA configuration?
Related Articles
Updated 11 months ago
Version 3.0
