Knowledge Base Article
IP Upgrade tool erroneously reports that your current IP core must be updated
Description
The Quartus II software version 14.1 requires that you specify a device if your IP core targets the Arria 10 device family.
If you generate your IP core outside of a Quartus II software project (such as through the command line using qsys-edit, or within the Quartus II GUI), and you did not specify your target Arria 10 device, when you add your IP variation to your
project, the IP Upgrade tool reports that version 14.1 of your IP core is out-of-date and must be updated to version 14.1.
This issue affects several IP cores, including, but not limited to:
- Arria 10 Hard IP for PCI Express
- 50G Interlaken Megacore function
- 100G Interlaken Megacore function
- Arria 10 1G/10GBE and 10GBASE-KR PHY
- RapidIO Megacore function
- RapidIO II Megacore function
- SerialLite III Streaming MegaCore function for Arria 10
Resolution
If you do not specify a device and you generate your IP core outside a Quartus II software project, when you add your IP variation to your project, upgrade your IP variation when prompted by the IP Upgrade dialog box.
