Knowledge Base Article
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/bsyn_interface/bi_bsyn.cpp, Line: 171
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 17.1 Update 1 and later, you may see this internal error during the fit stage. This problem only occurs when targeting Intel® Stratix® 10 devices.
Resolution
To work around this problem, add this constraint in the Quartus Setting File (.qsf) and recompile the project.
set_global_assignment -name PHYSICAL_SHIFT_REGISTER_INFERENCE OFF
Updated 11 months ago
Version 3.0
