Knowledge Base Article
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_re_network_routing_constraints.cpp, Line: 1421
Description
Due to a problem in Intel® Quartus® Prime Pro Edition Software version 22.4, you might see this internal error during the Fitter stage. This problem only occurs when targeting Intel® Arria® 10 devices.
Resolution
To work around this problem, change the following fitter setting:
  1. Go to Assignments > Settings > Compiler Settings > Advanced  Settings (Fitter).
  2. Set Periphery to Core Placement and Routing Optimization -> OFF.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 23.2.
Updated 11 months ago
Version 3.0
