Knowledge Base Article
Internal Error: Sub-system: U2B2_CORE, File: /quartus/h/u2b2_common_sys.h, Line: 34
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4, this internal error may occur when applying 3V Low-voltage CMOS (LVCMOS) with Weak Pull-Up IO standard assignments when targeting an Agilex™ 5 FPGA.
Resolution
To work around this problem, either remove the Weak Pull-Up assignment or apply the Weak Pull-Up assignment to all pins in the same IO bank.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
