Knowledge Base Article
Internal Error: Sub-system: U2B2_CDB, File: /quartus/db/u2b2/u2b2_re_network_checker.cpp, Line: 174
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.3 and earlier, you might see this internal error when you compile the implementation revision of your Partial Reconfiguration design. This error occurs when targeting Intel Agilex® devices.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 22.3. Download and install Patch 0.72 from the following links:.
- Intel® Quartus® Prime Pro Edition Software v21.4 Patch 0.72 for Linux (.run)
- Intel® Quartus® Prime Pro Edition Software v21.4 Patch 0.72 for Windows (.exe)
- Readme for Intel® Quartus® Prime Pro Edition Software v21.4 Patch 0.72 (.txt)
This problem was fixed in version 22.4 of the Intel® Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
