Knowledge Base Article
Internal Error: Sub-system: U2B, File: /quartus/db/u2b/u2b_av_m10k_param.cpp, Line: 2018
Description
Due to a problem in the Quartus® II software version 13.0, you may see this error if your design contains a single-bit width M10K memory. This problem affects designs targeting Arria® V or Cyclone® V devices.
Resolution
A patch is available to fix this problem for the Quartus II software version 13.0 with device patch 0.dp2. Before installing this patch, you must install device patch 0.dp2 from the related solution below.  After installing device patch 0.dp2, download and install patch 0.dp2d from the appropriate link below:
This problem is scheduled to be fixed in a future release of the Quartus® II software.
Related Articles
Updated 4 months ago
Version 4.0
