Knowledge Base Article
Internal Error: Sub-system: TIS, File: /quartus/tsm/tis/tis_physical_timing_stratixv_lab.cpp, Line: 161
Description
Due to a problem in the Quartus® II software version 13.1 and earlier, you may see this internal error during the fitter stage of a compilation of your Arria® V, Cyclone® V, or Stratix® V design.
Resolution
To work around this problem, download and install patch 0.44 from the links below. You must install Quartus® II software version 13.1 before installing this patch.
- Download the Quartus II software version 13.1 patch 0.44 for Windows (.exe)
- Download the Quartus II software version 13.1 patch 0.44 for Linux (.run)
- Download the Readme for the Quartus II software version 13.1 patch 0.44 (.txt)
This problem is fixed beginning with the Quartus® II software version 13.1.2
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
