Knowledge Base Article
Internal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_delay_budget.cpp, Line: 1495
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.4 and earlier, you might see this error during the fitter stage when compiling designs targeting the Agilex® 7 FPGA devices.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software version 22.4.  Download and install Patch 22.4-0.16 from the following links:
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 23.1.
Updated 4 months ago
Version 4.0
