Knowledge Base Article
Internal Error: Sub-system: QHD, File: /quartus/comp/qhd/qhd_database_model_utils.cpp, Line: 828.
Description
You may see this error when compiling the Partial Reconfiguration (PR) Implementation Revision. This error occurs when the design includes HSSI/PCIe ports that drive a PR partition that does not have any fan out in the PR Base Revision. This problem only affects Intel® Arria® 10 devices.
Resolution
To solve this problem, perform either of the following actions:
- Add fanout to these HSSI/PCIE ports in the PR Base Revision.
- Disconnect these HSSI/PCIE ports from the PR partition in the PR Base Revision.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
