Knowledge Base Article
Internal Error: Sub-system: QHD, File: /quartus/comp/qhd/qhd_database_model_utils.cpp, Line: 828
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.3 and earlier, you might see this error when running the partial reconfiguration compilation and targeting an Intel Agilex® device.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 22.1.  Download and install Patch 0.33 from the following links:
This problem is fixed in version 22.4 of the Intel® Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0
