Knowledge Base Article
Internal Error: Sub-system: PMB, File: /quartus/periph/pmb/pmb_module_gen7.cpp, Line: 1306; Cannot instantiate LSM_BF atom and other LSM atoms at same time
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.3, you may see this internal error when compiling a design that targets an Intel® Stratix® 10 device. This error occurs when there are no more LSM atoms available to reset the debug logic to a known state during power-up.
Resolution
To work around this problem, add an Intel® Configuration Reset Release Endpoint to Debug Logic IP from the Intel® Quartus® Prime Pro IP Catalog to the design. This means the IP must be created, added to the project, and instantiated in the design. This IP can be found in Intel® Quartus® Prime Pro by navigating in the IP Catalog to Library > Basic Functions > Simulation; Debug and Verification > Debug and PerformanceConnect the conf_reset input of this IP to a post-configuration reset signal to ensure that debug logic on the device operates from a reliable initial state.
This problem is fixed starting with Intel® Quartus® Prime Pro Edition Software version 22.1.
Updated 2 months ago
Version 2.0
