Knowledge Base Article
Internal Error, Sub System: Lchip : File: /quartus/legality/lchip/lchip_rowclock_router.cpp, line : 1944
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 18.0 Update 1, you may see this error in the routing stage when your design has Partial Reconfiguration regions enabled.
Resolution
To work around this problem, for the Intel® Quartus® Prime Pro Edition software version 18.0 Update 1, download and install patch 1.33 from the links below. You must install the Intel® Quartus® Prime Pro Edition software version 18.0 Update 1 before installing this patch.
Download the version 18.0 Update 1 patch 1.33 for Windows (.exe)
Download the version 18.0 Update 1 patch 1.33 for Linux (.run)
Download the Readme for the Intel Quartus Prime Pro edition software version 18.0 Update 1 patch 1.33 (.txt)
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 18.1
Updated 4 months ago
Version 4.0
