Knowledge Base Article
Internal Error: Sub-system: LAB, File: /quartus/legality/lab/lab_nd_config_creator_module.cpp, Line: 1062 An illegal ALE was detected.
Description
Due to a problem in the Intel® Quartus® Prime Pro edition software version 20.1 and 20.2, you may see this internal error during the fitter stage.This problem only occurs in designs targeting eSRAM Intel® Stratix® 10 FPGA IP.
Resolution
To work around this problem, perform the following actions
1. open /esram_1914/synth/_1914_<>.sv
2. find the c0_sd_n_0_reg signal and remove the altera_attribute as follows.
    (before)           (* altera_attribute = "-name FORCE_HYPER_REGISTER_FOR_UIB_ESRAM_CORE_REGISTER ON"*)  logic  c0_sd_n_0_reg/* synthesis dont_merge */;
    (after)                 logic  c0_sd_n_0_reg/* synthesis dont_merge */;
3. repeat same changes for all other signals for c1_sd_n_0_reg to c7_sd_n_0_reg if you use other eSRAM channels.
This problem is fixed beginning with version 20.3 of the Intel® Quartus® Prime Pro edition software.
Updated 11 months ago
Version 3.0
