Knowledge Base Article
Internal Error: Sub-system: EMIF, File: /quartus/periph/emif/emif_gen6.cpp, Line: 832
Description
Due to a problem in the Quartus® II software version 14.1 and earlier, you may see this internal error when you use an IOPLL cascade output as the reference clock source for an EMIF IOPLL. This problem only occurs in Arria® 10 devices where the configuration is not supported.
Resolution
To avoid this internal error, do not implement this unsupported configuration.
Future versions of the Quartus II software are scheduled to generate an error message when an IOPLL cascade output is used as the reference clock source an EMIF IOPLL.
Updated 11 months ago
Version 3.0
