Knowledge Base Article
Internal Error: Sub-system: DEV, File: /quartus/ddb/dev/dev_basic_info.cpp Internal Error: Sub-system: DYGR, File:/quartus/ddb/dygr/dygr_device_record_manager.cpp
Description
Due to a problem in the Quartus® II software version 12.1 and earlier, you may see these error messages when compiling designs with physical synthesis enabled. This problem affects designs targeting Cyclone® V devices if Arria® V device librares are not installed.
Resolution
To work around this problem, install Arria V device libraries.
This problem is fixed beginning with the Quartus II software version 12.1 SP1.
Updated 11 months ago
Version 3.0
