Knowledge Base Article
Internal Error: Sub-system: BITASM, File: /quartus/pgm/bitasm/bitasm_family_var1.cpp, Line: 10660
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1 and earlier, you may see this internal Error when you choose to encrypt the configuration bitstream (for Phase2 or Partial reconfiguration) and select "Quad SPI flash" as the encryption key storage location. The problem only affects the Agilex™ 7 FPGA devices. This option is not valid and should not be shown as an option.
Resolution
To work around this problem, choose the Quad SPI Intrinsic ID PUF-wrapped or Quad SPI UDS Intrinsic ID PUF-wrapped instead of the Quad SPI Flash option.
  • Go to Assignments -> Device -> Devices and Pin Options -> Security.
Select Quad SPI Intrinsic ID PUF-wrapped or Quad SPI UDS Intrinsic ID PUF-wrapped as Encryption key storage location.
The Quad SPI flash cannot be used as an Encryption key storage location for the Agilex™ 7 FPGA devices. This option will be removed from the Device and Pin Options GUI in a future version of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
