Knowledge Base Article
Info(208543): No frame error detected in device <n>.
Description
You might see this message when reading the EMR after injecting errors into Intel® Stratix® 10 or Intel Agilex® 7 FPGAs using the Fault injection Debugger if you have not enabled the "Allow SEU fault injection" option in the Intel® Quartus® Prime Pro Edition Software.
Resolution
To avoid this message, enable the "Allow SEU fault injection" option in the Intel® Quartus® Prime Pro Edition Software or manually add the following assignment to your .qsf file:
set_global_assignment -name ALLOW_SEU_FAULT_INJECTION ON
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
