Knowledge Base Article
How to constrain virtual pins for timing analysis in the Quartus® Prime Software?
Description
In the Quartus® Prime Software, the Timing Analyzer uses a 0ns clock insertion delay for virtual pins since they do not have an associated clock. This results in a large clock skew between the source and destination clock paths.
Resolution
To avoid this timing violation, perform one of the following two options:
  • Create a register wrapper design around the virtual pin so that it has an associated clock.
  • In the Quartus® Prime Pro Edition Software version 17.1 and later, you can use the constraints below:
    Virutal pin as an input port: set_input_delay -clock <clock port> -add_delay <delay> <virtual input pin> -reference_pin <the clock pin of the register that feeds the input port>
    Virutal pin as an output port: set_output_delay -clock <clock port > -add_delay <delay> <virtual output pin> -reference_pin <the clock pin of the register that feeds the output port>
Updated 3 months ago
Version 3.0
