Knowledge Base Article
How to adjust GTS PMA fractional PLL frequency in simulation?
Description
The GTS Transceiver PHY User Guide describes the sequence to change GTS PMA Fractional PLL frequency as follows. However, in simulation, after step 1, the frequency will reflect the new value without needing to execute step 2. This issue only exists in simulation. In hardware testings, you still need to follow the User Guide guidelines.
Tuning the k Counter Value in Fractional Mode
You can configure the GTS PMA in fractional mode to adjust the frequency and data rate by +/- 1000ppm for rate matching purposes.
Each GTS PMA has an Avalon® memory-mapped interface register containing the K value. The K value / 2^22 gives the fractional value of the feedback counter. The fractional value plus the M counter value provides the total feedback counter and determines how much PPM each bit in the K value represents.
The procedure to change the K value is:
  1. Change the K value to the new value.
  2. Pulse the strobe bit 0 -> 1-> 0 to lock in the new K value.
Resolution
  • In hardware testing, you need to follow the User Guide guidelines.
  • In simulation, you can perform the step 1 only.
There is no plan to fix the problem.
Updated 5 days ago
Version 2.0
