Knowledge Base Article
How do I perform word alignment in the Intel® FGT or FHT transceiver F-Tile PMA/FEC Direct PHY Intel® FPGA IP?
Description
There is no word alignment logic function in the Intel® FGT or FHT transceiver of the F-Tile PMA/FEC Direct PHY Intel® FPGA IP when you are not using the FEC.
Resolution
When you are not using the FEC in the Intel® FGT or FHT transceiver F-Tile PMA/FEC Direct PHY Intel® FPGA IP, you can implement your own word alignment logic on the rx_parallel_data bus in the FPGA fabric.
Updated 2 months ago
